Working backlight ETA?
Re: Working backlight ETA?
2 years 4 months ago
#2758
Not a good solution.
The battery is not user replaceable. The lifetime of the remote is limited by the battery.
Nothing destroys a lithium ion battery faster than letting it run completely dry.
Are you sure there is no way to do this remotely? Does it require special hardware?
I assumed that it would be possible for me to connect the base to the PC via USB, and you communicate with the remote when docked in the base. If I install Team Viewer on the PC, can you remote in and do what needs to be done?
#2759
We assume the remote is "dead" and can't be communicated with.
So, if the hard button power doesn't do the job, I don't see any other alternatives.
BTW, we will stock replacement batteries and already have replacement back panels that likely get hurt when the remote is taken apart.
#2760
Sorry for the confusion. I wasn't asking for another way to power off the device. I was asking why the re-install of the OS can't be done remotely.
#2761
Charge it and send it next day. It is not possible / impractical to update the firmware remotely.
#2762
It is a violation of federal law to ship it powered on.
LimeyFK's Avatar
#2780
I had an error on step 7 and figured it'd be best to ask for guidance before proceeding given some of the other reported challenges.
Step 7
Post reboot of the SmartRemote, do a "Install" from the AndroidTV Driver command list.  Select smartremote as the device type.  Run this command.)
I waited for the SmartRemote app icon to populate on the SmartRemote but it never appeared.  In checking the system events log, I saw:
[Error: AndroidTV: SendCommand: ERror in SendCommand - An error occurred while reading a response from ADB: closed]
Should I try the command again?  Or, should I go back to step 6 first to run the ForcedUninstall before trying the command again?  I do see the SmartRemote listed again in the AndroidTV driver but there's no icon on the SmartRemote itself.
If it's helpful, the command I issued for step 7 was AV|68~Install~smartremote.apk .  I did ping the SmartRemote first to confirm it was online and everything looked normal.  I appreciate the guidance!  I'll wait to hear from you before proceeding any further.
Thanks,
Neil
