Driver Releases
randyf's Avatar
Re: Driver Releases
#1655
How about a driver for the HTD Lync whole house audio system.
I have some docs that have info on their RS232 interface.  There's also some work done with Python scripts for home assistant here:  github.com/UngluedChalice/htd-lync12-home-assistant and someone else did something with Python as well:  github.com/qguernsey/Lync12
PhoenixF15E's Avatar
Re: Driver Releases
#1656
Kodi would be a good one for a lot of people I expect.
and Plex
A second vote for Plex!
Re: Driver Releases
#1658
Pioneer receivers would likely be helpful for many.  I have a VSX-1124, but I suspect the control language hasn't changed too much and would work on many other models.
Link to Pioneer VSX-1124 spreadsheet
Link to AVR control webpage
RxJoshRx's Avatar
Re: Driver Releases
#1660
Yamaha AVR driver would be great. Running everything through IR right now and have to be careful when we hold the volume up/down too long- after we release sometimes it will continue on for another 5-10 units. 😬
kirky27's Avatar
Re: Driver Releases
#1661
I notice there is no discover button for the Oppo driver
Re: Driver Releases
#1667
I guess first make sure that you haven't got long-press on your volume keys defined to run a loop of 10 as they were originally in the smart remote sample. Then you could try using the IP control protocol documented here github.com/nicko88/HTWebRemote/blob/mast...ents/Yamaha_YNCA.pdf and here  github.com/nicko88/HTWebRemote/blob/mast.../Yamaha_Commands.txt and see if that's better.
Make sure netcat (nc) is installed on your myServer box then cook up some scripts that contain nc commands such as these:
allonis@myserver-360:~ $ echo "@SYS:PWR=On" | nc -w 1 -C yamaha-amp 50000 @MAIN:PWR=On @MAIN:AVAIL=Ready @MAIN:INP=HDMI2 @MAIN:MUTE=Off @MAIN:PUREDIRMODE=Off @MAIN:SOUNDPRG=Surround Decoder @MAIN:STRAIGHT=Off @MAIN:VOL=-32.0 @ZONE2:PWR=On @ZONE2:AVAIL=Ready @ZONE2:INP=AUDIO1 @ZONE2:MUTE=Off @ZONE2:VOL=2.5 @SYS:PWR=On @SYS:DMCCONTROL=Enable @SYS:HDMIOUT1=On @MAIN:VOL=-40.0 allonis@myserver-360:~ $ echo "@MAIN:VOL=?" | nc -w 1 -C yamaha-amp 50000 @MAIN:VOL=-40.0 allonis@myserver-360:~ $ echo "@MAIN:VOL=Up 1 dB" | nc -w 1 -C yamaha-amp 50000 @MAIN:VOL=-39.0 allonis@myserver-360:~ $ echo "@MAIN:VOL=Down 1 dB" | nc -w 1 -C yamaha-amp 50000 @MAIN:VOL=-40.0 allonis@myserver-360:~ $ echo "@MAIN:VOL=Down 5 dB" | nc -w 1 -C yamaha-amp 50000 @MAIN:VOL=-45.0 allonis@myserver-360:~ $ echo "@MAIN:VOL=Up" | nc -w 1 -C yamaha-amp 50000 @MAIN:VOL=-44.5 allonis@myserver-360:~ $ echo "@SYS:PWR=Standby" | nc -w 1 -C yamaha-amp 50000
For instance have a "vol-up.sh" script that contains:
Then have your volume up key run that script on the server.
Note - I haven't tried this so running a script each time might be too slow, or it might not be a good idea for another reason.
You might even be able to do this directly in myServer using the SendTCP command but each message string has to end with 0x0d 0x0a line ending and I don't know if you can specify that.
Last edit: 2 years 6 months ago by andrew.
The following user(s) said Thank You: RxJoshRx
Time to create page: 0.370 seconds
