Driver Releases
kirky27's Avatar
Re: Driver Releases
#1644
I would like a driver for the Storm Audio processors.
www.stormaudio.com/wp-content/uploads/20...ocol_fw4.3r0_v20.pdf
Thanks.
Last edit: 2 years 6 months ago by kirky27.
Re: Driver Releases
#1649
Kodi would be a good one for a lot of people I expect.
Re: Driver Releases
#1650
And for me I'd like to see Yamaha AV amp control. Our current one (RX-V677) is supported by this  github.com/nicko88/HTWebRemote/blob/mast...ents/Yamaha_YNCA.pdf and I guess there's a more modern version for current models (e.g. RXV6A) if they don't still use the same protocol. Or one could reverse engineer the http interface.
github.com/nicko88/HTWebRemote/tree/mast...l%20Spec%20Documents is a good source for a whole bunch of devices.
Re: Driver Releases
#1651
Final one which is probably a bit niche so I don't expect it soon if ever. Sky satellite boxes, specifically Sky+HD and SkyQ (in the UK anyway). Our current Sky+HD box works with  github.com/OliWright/mqtt_sky/blob/main/skyremote.py which is pretty simple (albeit only one way). I've no idea what SkyQ (the current generation) supports.
If you released the source code for a sample, simple driver (e.g. one way control of a set top box) I expect at least a couple of us on this forum could whip up a basic driver for our own devices and pass it back to you for others to use. I'm assuming the drivers are all written in C# .NET.
CrabbyPatties's Avatar
Re: Driver Releases
#1652
and Plex
LimeyFK's Avatar
Re: Driver Releases
#1653
I'd like to add JRiver Media Center to this list too.
